Help with rear end
Old Aug 8, 2017 | 09:53 PM
seevi's Avatar
seevi
Default Help with rear end
I have the opportunity to pick up a very low mileage C6 Grand Sport 2.76 differential. I have a base model ‘07 and want to know if that is a bolt In swap before I buy it. Thanks
Old Aug 8, 2017 | 10:11 PM
RicK T's Avatar
RicK T
Need to clarify, are you talking about the whole differential case and guts or just the guts? Also, what year GS? It may make a difference. Is your '07 an A6 or M6 trans?
Just FYI, there was no 2.76 diff. The GS's were 2.73 with the A6. Just sayin'.
I probably can't answer you but there will be others here who can, so if you can provide the additional info it would help.
Old Aug 8, 2017 | 10:19 PM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
RPM Transmissions (forum vendor) lists Grand Sport manual rear ends being interchangeable with ZO6s. So you would probably need one from an automatic model.
Old Aug 8, 2017 | 10:24 PM
seevi's Avatar
seevi
2.76 was a typo. My car is an A6.
To Help with rear end
