Easy trim addition to radiator top edge
Found my ECT dropped 5-8 degrees in traffic after removing the cover that came with my ECS kit but didn't like the look of the raw edge of the radiator, especially after cutting it with a hacksaw and beating the edge down with a hammer.
Bolted 2 pieces of 1" x 1" x 1/16" angle together and was a perfect snug fit to slide over the top of the radiator. $12 Total.
That's a neat cheap way to cover that channel on top of the stock rad.
The better, albeit slightly more expensive, way would have been to install a Dewitt's.
Your coolant temps dropped after you removed that cover?
That's weird. I would have thought the opposite would happen?
Wait, where's your AC condenser core?
Car's just a garage queen and not driven in the extreme heat or cold but might put the condenser back in during the off season.
It never really ran hot, always under 210f in traffic with temps in the 90s, but traffic around here means stopping for the cows or chickens next door to cross the road.. Just had the cover off for other reasons and noticed temps dropped, probably not pulling in hot air from the pavement anymore when stopped, and my hoot is vented so there's that.
I would've thought that could only make your car run warmer. Looks like, as with everything, it's a sum of the total that affects cooling on these cars. I took the shroud off mine a while back, and I thought that would make it run hotter, but my car never gets over 205*, even in stop and go traffic with the A/C on. But maybe that's because I have a modded Halltech Beehive that directs the air through the rad.
We have lots of cows and chickens crossing the road here too, btw. The cows are usually the two-legged kind though.
Northwest corner... Near the Delaware water gap. Lots of farms, cattle and corn.
I'm just leaving everything as is unless it gets near 220f.
Last time I was in the Caymans I remember a guy ripping the husk off a coconut with his teeth then demanding $5 because I watched him. I just forked it over to avoid an argument. Rented a jeep to get away from all the tourists and had a great time...didn't see any cows, it was either scantily clad women or locals
I didn't know you'd been down here to the Rock. I'm pretty sure that fool with the coconut was a little local hustler called Georgie. He rolls around town with a shopping cart full of coconuts that he steals from everyone's trees, peddling them to tourists. Real piece of work - I've actually locked him up before for poaching conchs in a marine park and for theft. He hates the sight of me, lol.
Man, somehow we've digressed from engine cooling to street vending...
If you ever come down this way again make sure you look me up.
I was surprised to find my car ran cooler with the shrouding off as well. Only problem I found is that the car actually runs hotter during high mph pulls or getting on it at high mph. It stays cooler during idle and sitting in traffic though so I suppose its all in what you need.
