I have a brand new LS3 with a cam in my 1967 GTO. Great motor of course, and there is nothing better than cruising in this old muscle car. After 2500 miles I had it tuned by a very experienced tuner. He did a great job improving the everyday, around-town drivability. However the dyno revealed a dip in the torque curve at about 4700 rpm that he could not tune out (attached). He thinks it could have something to do with the ground or the 50 yr old ignition switch. The builder is a EE who consults for power generation plants so he knows how to ground things, however the igintion switch was problematic during the build. Apparently these old switches are not designed to keep power to the computer during starting. He had to wire it differently but that's all I know. Question: Has anyone experienced this type of torque curve and if so, what was the cause and fix? I am not hesitant about having my builder putting in a new ignition switch so if this could be the cause does anyone have any recommendations for the actual switch model number to use? This winter I want to add a super charger but I am not going to do it until the motor is running right to begin with. Thanks all.
Assuming yo mean peak (not pick) that's an interesting thought. Im rrunning 275's on the rear and clearly the car was strapped, but still, I'll run it by the tuner. Thank you.
Fixed, I know some of us screw up every now and then I choose not to correct others tho cause of me ha-ha.
My car was loosing traction with 335 35 17 Hoosier drag radials on a knurled roller applied some VHT track bite done.
Thanks. I have no experience with tuners so I could only go by what others at car shows and my builder suggested. I ran the notion of wheel slippage by him and he says there definitely was no slippage. Someone has the answer. I'll find it.
Wouldn't you see a spike when it picked traction back up instead of gradual smooth curve?
Will return to where is max power at that point, loss of traction doen't add power so no spike in his case as it wasn't a severe loss so it just cut up.
Op it doesn't appears as torque converter generated.
