Fed Up With Corvette
Old Aug 27, 2017 | 08:01 PM
carls2004's Avatar
carls2004
Originally Posted by Old Ben
Bypassing the system so that you can watch video while driving? Sounds about as sane as texting your way down the road. Just my opinion but there are enough distractions already.
They have that safety feature on the system for a reason.
Dont worry i dont play video in unit.. BUT there is still some features that i like to adjust or see on the fly so it is needed....
Old Aug 28, 2017 | 05:09 PM
carls2004's Avatar
carls2004
Pulled all aftermarket system out this afternoon... Erased code and all comes back on...So i see that there is no communication of any sort on my install with the ABS system... Checked a little more with volt meter at ABS, and ECM since i cant communicate with it since it got worse.. So i went to a friend who has a shop and told him my diag is bad ABS. module and must of been a fluke...
So he tested everything and he comes up with same result's..
Electrical yuk.. Must of just been a fluke when it took a crap after radio install...
So i have a unit on the way....
Old Sep 2, 2017 | 04:14 PM
carls2004's Avatar
carls2004
YEA.. I got my used ABS unit in.. So i took the elec module off new used unit and installed it on mine.. YES, ABS light and E brake LIGHT are off now and my steering is back...
Anyone who has read any of this post will see that my abs problem started immediately when i installed new sterio head unit.. BUT it was all a fluke that it happened to go bad right then...
Old Sep 3, 2017 | 10:34 AM
BigBlok502's Avatar
BigBlok502
That's great news, glad to hear you got it all sorted out.
Old Sep 10, 2017 | 08:48 PM
Wampa's Avatar
Wampa
Glad you got it figured out! Hope to see soon that you got all of your equipment back in with no issues!
Old Sep 11, 2017 | 02:23 PM
carls2004's Avatar
carls2004
Yes it is all back together.... Not to go off subject, but when i unbolted the electric module from the ABS motor, i found out why mine went bad...
Brake fluid is getting into it.. So for rest of season ill run it with the used module on the orig leaking pump and swap out pump in the spring...
Another note would be is my car is a 2006, and i found a good used unit off ebay for 150.00 and it was off a 2007 and had same code on the outside, so i Didnt need anything programmed like some may think.
