Mega Death Cam questions
Old Sep 5, 2017 | 04:25 PM
Lsx.thomas's Avatar
Lsx.thomas
4th Gear
Default Mega Death Cam questions
Before I get the ole "this has plenty of threads" answer I obviously didn't find what I needed. So I am about about to buy a Megadeath cam 244/242 on a 112 LSA w/ .612/.610 lift and yes I do know this is a big cam. What supporting mods do I need it's pretty much stock engine with full bolt ons. It's the ls2 version of the C6, heads are bone stock. The kit comes with Trend 7.400 chromemoly pushrods and Brian Tooley Racing .660 dual springs. What else do I need I am dumb when it comes to the valvetrain. Thanks !
Old Sep 5, 2017 | 08:33 PM
tuboy19's Avatar
tuboy19
A different cam
Old Sep 5, 2017 | 08:45 PM
Lsx.thomas's Avatar
Lsx.thomas
4th Gear
Originally Posted by tuboy19
A different cam
Want to give me a suggestion? I want a loud lope. A different cam isn't really convincing just sayin
Old Sep 5, 2017 | 11:02 PM
xBoostx's Avatar
xBoostx
Hey Thomas if it only cost you 40. and I did every thing you want will you be willing to pay it? I'm and that's what i do cause you can't beat it!
I have an ls3 with 14.1 compression and 240 degrees duration intake @ .050 is a llsr shift points at 7,200 and is a little on the large side.
My suggestion get a hold of Patrick G fill out his long questionnaire take as much time as you need and get the perfect cam for your purpose, Oh and will do more than you ask, here's hint don't change any thing from the proposal specs Just trust him I should have.
Hope this helps is what every body in competition does cause changing a cam is a lot of money a lot of work and down time so what's not to like to get it rite the first time.
Let us know how it went & get us in on the specs if you don't mind enclose is a link.
I use these guy for every engine i build and wouldn't do it any other way, best regards Dave.
https://www.guerragroup.com/camshaft-help
Old Sep 5, 2017 | 11:10 PM
Lsx.thomas's Avatar
Lsx.thomas
4th Gear
Thank you! Probably the direction I need to go since I have no clue what I am doing haha
Old Sep 6, 2017 | 12:20 AM
CI GS's Avatar
CI GS
A different cam
For a stock head LS2, I would try something like the Spinmonster cam, which has been tried and proven to make serious power.
Or better yet, as suggested by xBoostx, contact Pat G and get him to spec you cam based on what you want.
Old Sep 6, 2017 | 11:21 AM
2L8LUZ's Avatar
2L8LUZ
If you want a killer sounding cam-
The BTR-4 is simply amazing... if you don't mind all the cam shake at stoplights...
It is mean as F$$$ and breaths to 7100 rpms..
After all of my little issues that were fixed after installation- different airbox etc.
I made 500/459 on the corn in 90+ degree weather
Tuner dialed in and I can cruise in 6th gear at 1200 rpms all day long!!
Old Sep 6, 2017 | 02:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I am going with PatG myself and I took my time filling in the whole questionnaire. I have my specs now and I am having Texas Speed doing the Cam Grind -
By far this is the best way to go, you won't be disappointed at all -
Thanks,Matt
Old Sep 7, 2017 | 06:13 PM
BigVette427's Avatar
BigVette427
Thanks,Matt
I as well went with a custom grind from TSP off their new Landis LT1VE once I did my research and got the specs that I was looking for; I can't wait to get my heads from AHP so I can install, tune, and dyno it all. I suggest you go with the 8620 core as it's only like $50 more.
https://ls1tech.com/forums/advanced-...ifference.html
Old Sep 7, 2017 | 10:31 PM
madmatt9471
Right on! - thanks
Thanks,Matt
Old Sep 8, 2017 | 08:40 AM
Brandon619's Avatar
Brandon619
I choose a Spinmonster cam, great cam.
Old Sep 10, 2017 | 04:46 PM
jayyyw's Avatar
jayyyw
Thanks,Matt
How long did it take you do get the specs? I am filling out a questionnaire now.
Old Sep 10, 2017 | 04:59 PM
64drvr's Avatar
64drvr
St. Jude Donor '15
If you want a car that is very tempermental, surging idle that requires your attention to keep it idling, and a mediocre power increase - this sounds like a great plan.
If you want a car that has a very pronounced lopey idle that also is rock solid reliable idling as well as a strong running engine you should take the advice of everyone here. A spinmonster grind or something in the low 230s intake/mid 230s exhaust/mid 600 lift- 8-12 deg overlap would do the trick.
Old Sep 10, 2017 | 05:01 PM
jaybee924's Avatar
jaybee924
I did the $25 dollar one in the morning and it came in the next day after lunch. But it didn't take long. I guess it depends on how busy he is.
Old Sep 10, 2017 | 05:53 PM
madmatt9471
Since I was not in a rush I opted for the $25 wait -
It took 12 days to get my specs to be exact - August 4th, 2017 to August 16th, 2017
When I Paypal'd the money and Spec sheet to PatG that very night he got back to me as follows: 8:39 PM California time and PatG answered at 9:39 PM California time according to my emails.
I hope this helps.
Thanks,Matt
Old Sep 10, 2017 | 05:55 PM
jayyyw's Avatar
jayyyw
I hope this helps.
Thanks,Matt
So went through a few different variations, if I'm reading that correctly?
Old Sep 10, 2017 | 05:56 PM
madmatt9471
Yes and as others have said - it can depend on his workload on how fast the deposit of $25 for the specs takes -
Be as detailed as possible, read it over and then re-read it again - Especially the REASON for the New Camshaft
Every detail helps - you can find specs for your motor in the internet if you want to input those as well -
Thanks,Matt
To Mega Death Cam questions
Old Sep 10, 2017 | 05:59 PM
madmatt9471
Nah - I submitted it on August 4th and he got back to me immediately (which was awesome in its own rights) - just showing a time frame how quick he got back to me after I Paypal'd -
Then it took the 12 days to get the actual specs -
I just placed my order with Texas Speed and got other things for the Cam Swap from them very reasonable too -Talk with TSP if you decide to go with them to grind the Cam for the supporting parts -
Thanks,Matt
Old Sep 10, 2017 | 07:16 PM
jayyyw's Avatar
jayyyw
Thanks for the info. I've looked it over all day and got all info I was not sure about off the interwebs. Will submit it tomorrow and see what happens!
Old Sep 23, 2017 | 07:54 PM
fmijares's Avatar
fmijares
https://youtu.be/Ji9X1aE3fC4
nice to see you on here lee. those are some crazy good #s.
