Harmonic Balancer 2007 C6 LS2 6.0L
Old Sep 27, 2017 | 12:10 PM
Bugsy 47's Avatar
Bugsy 47
4th Gear
Default Harmonic Balancer 2007 C6 LS2 6.0L
2007 C6 LS2 6.0L with a manual transmission.
The Harmonic Balancer came loose and I obviously did not have it marked with the crankshaft. I have the proceedure to torque it back into place, but how do I determine the correct position rotationally on the crankshaft?
Old Sep 27, 2017 | 02:24 PM
schizcat's Avatar
schizcat
Here are a few tips about the HB:
1) Replace it...do a search on here and you will see why. The HBs are known to fail.
2) No position necessary on the new HB. Just put it on.
3) Replace it
Old Sep 27, 2017 | 05:11 PM
HBsurfer's Avatar
HBsurfer
And use a new bolt. The one you have now is shot. You can only torque it one time (torque to yield).
Old Sep 27, 2017 | 05:33 PM
BigVette427's Avatar
BigVette427
PowerBond Race Series, I believe PB1117SS is the p/n you need for an LS2. Forged 1045 steel, SFI 18.1 rated, dynamically balanced, unique rubber and bonding process, clear coated finish and laser etching serial number, 10X the push strength of an OE HB, rated up to 9,500 rpm. Get it for $200+tax shipped for free to your door from AutoZone right now with the coupon code on the front page.
https://www.corvetteforum.com/forums...d-warrior.html
Old Oct 18, 2017 | 10:30 AM
Bugsy 47's Avatar
Bugsy 47
4th Gear
Default Oil Pressure at Idle
OK, New HB and bolt, but now the oil pressure at idle is around 15 psi. When the RPM comes up, so does the pressure to around 50 psi, but what does the HB have to do with the oil pump?
Old Oct 18, 2017 | 03:55 PM
irok's Avatar
irok
if all you have done is replace hb then oil pressure should not have been affected.did you do anything else at same time?
Old Oct 18, 2017 | 04:03 PM
DubsAndSubs's Avatar
DubsAndSubs
Did you put the little seal back on the end of the HB?
Old Oct 18, 2017 | 04:41 PM
BigVette427
Is that much different than what you remember before you swapped the balancer? GM does say it could get that low depending upon the temperature outside and how long it may be idling.
https://my.chevrolet.com/content/dam...tte_owners.pdf
Inspect around your crank bolt and oil pan to see if it's wet, and go from there.
To Harmonic Balancer 2007 C6 LS2 6.0L
