Normal clutch squeal?
Old Oct 1, 2017 | 11:36 AM
FlyboyZR1's Avatar
FlyboyZR1
Default Normal clutch squeal?
I just replaced my clutch fluid using the "ranger" method which involves pumping the clutch pedal 30 times after draining/filling the clutch reservoir.
I noticed that after about 15 clutch pumps it started making a slight "squeal" noise when depressing the clutch pedal. I came back the next day and tried again ... first 15 pumps sounded normal but after pumping the pedal 15+ times it makes a slight squeal noise. Sounds like it's from under the hood somewhere.
Is this normal or anything to worry about? Clutch works great and car drives great.
Old Oct 2, 2017 | 10:34 AM
FlyboyZR1's Avatar
FlyboyZR1
Ttt
Old Oct 2, 2017 | 02:24 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Compared to in the engine bay I'd look under the dash at the clutch pedal assembly. There is a small spring that frequently breaks and needs replacing. My guess would be either this spring needs a little lube, or is getting ready to break.
Old Oct 2, 2017 | 05:15 PM
extrapilot's Avatar
extrapilot
I suck out all the clutch fluid and replenish about 4 times a year, as I DD my car year round, but I don't pump the pedal, just drive the car, fluid looks clean.
To Normal clutch squeal?
