Question about speed density and maf
Old Oct 8, 2017 | 08:42 PM
UmX's Avatar
UmX
Default Question about speed density and maf
So I have a 2.5bar and a speedy density tune by dr phil.. I want to clean up the IC to TB piping.. Is there a way to get rid of the maf or run something else that doesnt need the whole maf housing?
Old Oct 9, 2017 | 10:04 AM
Raffman55's Avatar
Raffman55
2024 C6 of the Year Finalist - Modified
2018 C1 of Year Finalist
Not sure on the vettes but I looked into it for my truck with a built 6.0. You have to remove two wires from the MAF and run another MAP to engine vac and hook those two wires to that.What bar will depend on engine. Then you can remove your MAF from the intake piping. I'm sure if you google it you can find the specifics ...
Old Oct 10, 2017 | 08:58 PM
Unreal's Avatar
Unreal
Just need to add an IAT, then you can just remove it (and turn off maf codes in ecu so it doesn't do a CE light). I don't have a maf on my car.
To Question about speed density and maf
