TPMS Accuracy Question
Old Oct 11, 2017 | 12:26 PM
Charlie from Cherry Hill's Avatar
Default TPMS Accuracy Question
I keep close tabs on the PSI in our tires. C6, wife's Chevy and my Buick all have TPMS that are a couple of PSI less than my tire gauges read. I use a recently purchased digital gauge and also have an older analog dial gauge. The DIC always shows a different PSI on each vehicle than that of my gauges. Is this common? Dealer says the TPMS is very accurate (+/- 0.5). Your thoughts please.
Old Oct 11, 2017 | 01:13 PM
nuke61's Avatar
nuke61
Johnson Controls makes a large number of TMPS senders, and they say it's + or - 1 psi.
Old Oct 11, 2017 | 04:28 PM
Tonylmiller's Avatar
Tonylmiller
Mine have always been 1 or 2 psi off. Good enough to tell if there is a problem but if you want accuracy just use a good gauge on cold tires.
Old Oct 11, 2017 | 09:38 PM
Thanks guys. Looks like I'm okay using my tire gauge to fill the tire and the TPMS as a backup warning.
Old Oct 11, 2017 | 10:57 PM
cclive's Avatar
cclive
Exactly as the system is designed
To TPMS Accuracy Question
