QuickTime bellhousing alignment.
Old Oct 11, 2017 | 07:23 PM
ZYOUL8R's Avatar
ZYOUL8R
Default QuickTime bellhousing alignment.
Has anyone done this before with this bellhousing?
I am trying to align my bellhousing for concentricity and want to make sure I'm doing it correctly. The instructions say to measure to the register bore, however this is not a perfect circle because it is interrupted by the bolt holes, dowel pins and slave line cutouts.
I've seen that other models require that the faceplate of the transmission be bolted on to measure with. However that is not possible with this model. So how and where am I supposed to measure with this model? I want to make sure I am doing it correctly because I don't want to damage the new Mantic 9000 clutch $$$ that's going in with it!
Here is picture of how I am currently measuring after the first pass.
Thanks,
