OBD Port Not Working.
Old Oct 17, 2017 | 07:12 PM
The Problem Child C6's Avatar
3rd Gear
Default OBD Port Not Working.
I have a 2005 that's been cammed and full bolt ons. Got a decent tune on it before the cable shorted out. Went back to finish everything a few weeks later and HP tuners will not connect to it. Neither will a normal code reader. Anybody else have this issue or a solution?
Old Oct 17, 2017 | 07:37 PM
R_W's Avatar
R_W
Same thing happened on my Silverado, and it turned out that the cigarette lighter fuse was the same one powering the OBD port. I had popped the cig lighter fuse on accident, thus resulting in a failure-to-read OBD when I went for an inspection. I located and changed the fuse, all is well. Maybe start there...
Old Oct 17, 2017 | 07:40 PM
3rd Gear
Haven't heard that one yet I'll definitely have to check it. I was leaning towards bcm or ecm. But couldn't imagine the car running and driving without issues if one of them were bad especially the ecm.
Old Oct 25, 2017 | 10:02 PM
myjdm's Avatar
myjdm
Check theres power on the pin that should have power. Also check that the ground pin has ground. OBD2 port pin out:
Old Oct 25, 2017 | 10:21 PM
NY09C6's Avatar
NY09C6
Disconnect the battery for a few min then reconnect it. I had a similar issue with my truck a few years back.
To OBD Port Not Working.
