Rubbing sound
Old Oct 19, 2017 | 04:18 PM
gordosoar's Avatar
gordosoar
Default Rubbing sound
I have a rubbing scraping kind of sound coming from the right side of my car when I first start out driving. After a while and a few miles the noise stops. I thought it was a wheel bearing but when I checked to see if the wheel was loose,, it was very tight both front and back. does anyone have any idea what could be causing the noise.?
Old Oct 19, 2017 | 05:35 PM
rkj427's Avatar
rkj427
Pro Mechanic
might be time for a rear differential oil change..........................
possible clutch plates and original lube changing it's properties due to age/mileage
Old Oct 19, 2017 | 06:32 PM
gordosoar's Avatar
gordosoar
Rear oil has been changed twice in its life.
How about transmission?
Old Oct 21, 2017 | 08:07 AM
rkj427's Avatar
rkj427
Pro Mechanic
transmission should not be source of noise, would have other concerns besides the noise............
also the axle nuts may have lost torque even if wheels did not feel loose........
pretty easy to check them for torque just to be sure................
axle lube does degrade even if changed, and also it seems to matter which type of axle lube was used......................
Old Oct 21, 2017 | 09:07 AM
gordosoar's Avatar
gordosoar
When you say axle,,,what axle do you mean? Where is it lubed at?
I have checked to nut torque and it is correct.
When I had the brakes and shocks replaced the mechanic told me the boots were torn could this be part of the problem?
Also I noticed when I take my foot off the Excelerator the noise stops so if I’m just kind of coasting I don’t hear it but is soon as I step on the gas it comes back again but after a while no noise at all under any circumstance.
Old Oct 25, 2017 | 11:14 PM
gordosoar's Avatar
gordosoar
I was checking the noise again today and it seems to be coming from the front right of the car,,maybe in the engine compartment. Like the manifold maybe.
The sound goes away after the engine worms up.
Any other ideas?
Old Oct 26, 2017 | 07:54 AM
Kenny94945's Avatar
Kenny94945
Rubbing and scraping are two different sounds....IMO
More info needed.
In the mean time, sound may be tricky and it may not be from the right side.
Rubbing make me think something is rubbing a tire or perhaps a shock absorber or swaybar.
Scraping more difficult. Rear axle nuts are notorious/ Perhaps accessory belt pullies, torque tube/ axles, brake pads/ calipers - something metal to metal.
Interesting it is mentioned the sounds stop after a few miles or 5 minutes I assume.
Something expands with heat, centrifugal force centers, material wears away until next time...just thinking out loud with these comments.
Well, that's my two cent comments....good luck.
Old Oct 26, 2017 | 09:46 AM
gordosoar's Avatar
gordosoar
More info needed.
Thank you for your two cents those are really good suggestions. I just had the brakes and shocks replaced but this sound was coming from the car before this was done, and it seems to be getting louder over time.
I think it might be coming from somewhere around the manifold and as it heats up the sound disappears. it’s more of a hollow kind of a sound that is difficult to describe. The car will be going to the mechanic next week and I’ll have him look at it then.
Old Oct 26, 2017 | 11:26 AM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Leaking exhaust gasket? Just a wild guess.
Old Oct 26, 2017 | 11:35 AM
gordosoar's Avatar
gordosoar
Actually that might not be so wild, makes perfect sense will have to check it out
Old Oct 27, 2017 | 01:16 AM
torquetube's Avatar
torquetube
Any other ideas?
Next time you hear it, press the snowflake (A/C compressor disable) button and see if that makes the noise change or go away.
Old Oct 27, 2017 | 09:45 AM
gordosoar's Avatar
gordosoar
We have a cold front here so I wasn’t using the A/C yesterday and the sound was still there. But yesterday the car was outside and I found a black wet spot on the garage floor that looked like it came from the exhaust system. So I’ll have that checked when I have the car in the shop next week. Could turn out to be an exhaust leak.
Old Oct 30, 2017 | 09:43 AM
gordosoar's Avatar
gordosoar
Update.... upon further investigation I have found that it only makes the noise when the car is in gear. So now I’m thinking it has to do with the rear end,, maybe the differential of transmission. The trans is due for its 100,000 mile filter and fluid change which I will have done very soon. We will see if that eliminates the noise.
To Rubbing sound
