2005 C6 Column Lock
Old Oct 21, 2017 | 03:12 PM
Qcamel's Avatar
Qcamel
7th Gear
Default 2005 C6 Column Lock
Is there any way to unlock the column lock? Got fresh battery it started once then locked up when I turned it off and will not start/unlock.
Old Oct 21, 2017 | 07:46 PM
had3nuf's Avatar
had3nuf
When you push the start button does the dash display read steering column lock, and nothing happens ?
Old Oct 23, 2017 | 01:12 PM
rhoyvald's Avatar
rhoyvald
Yes - get the bypass module
https://www.corvettemods.com/C5-C6-C...it_p_6373.html
Old Oct 23, 2017 | 04:24 PM
Qcamel's Avatar
Qcamel
7th Gear
Yes, I get the message and nothing happens at all.
Old Oct 23, 2017 | 05:33 PM
EVRose's Avatar
EVRose
From what I've read on here disconnecting and reconnecting the battery usually will reset it.
Old Oct 23, 2017 | 08:12 PM
had3nuf's Avatar
had3nuf
Qcamel,
what rhoyvald suggested would be the best way to go, mine went out under warranty and it would have been $500 at the dealer.
Old Oct 23, 2017 | 08:14 PM
had3nuf's Avatar
had3nuf
when the steering lock malfunctions the ECU goes in to secure mode that's why it won't start
Old Oct 23, 2017 | 09:07 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
Originally Posted by rhoyvald
From what I understand that is a copycat of the one made by the original maker.
The original is supposed to be better. It's the one that I installed over two years ago and I have not had a column lock since. Here's a link to it on ebay.
https://www.ebay.com/itm/C6-2005-Cor...pRhGu6&vxp=mtr
Old Oct 24, 2017 | 10:57 AM
lovinmyls1's Avatar
lovinmyls1
Old Oct 25, 2017 | 09:06 PM
myjdm's Avatar
myjdm
I think I saw the modules on ebay for real cheap few months back
Old Oct 26, 2017 | 10:10 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Here is video, you can find others on u-tube.
Old Oct 26, 2017 | 01:37 PM
myjdm's Avatar
myjdm
Pretty simple...
To 2005 C6 Column Lock
