No Crank, No Start, 1-Code U0100
Old Oct 21, 2017 | 04:30 PM
Paul Theuer's Avatar
Paul Theuer
Navigator
Default No Crank, No Start, 1-Code U0100
I have been having a No Crank, No Start issue for the last month. The only code I have is a U0100 Lost Comm With ECM PCM A.
The only thing that I did and it was about the same time since I have been having this problem was installing a new Pioneer avic-8200 radio with backup camera. I connected the radio with the factory wiring harness which uses the rdo 15 amp fuse in the BCM. The radio and backup camera worked fine.
Yesterday I got the bright idea to remove this fuse to see if the radio install in effect has caused my problem and wallah, The car has been starting flawlessly and the code has disappeared.
I figured I would throw this out on the forum for knowledge and review.
Now I need to figure out how a aftermarket radio install caused these issues.
Old Oct 21, 2017 | 06:27 PM
Paul Theuer
Navigator
I spoke to soon. I got into the car and no crank. Finally got it to start with numerous attempts pushing the start button.
Old Oct 22, 2017 | 10:56 AM
All Stock Ls2's Avatar
All Stock Ls2
Is it a 2005 or 2006 and up? Also, do you have a message saying something about "column steering lock"? If not then check your starter solenoid I've heard of it causing an issue like that.
Old Oct 31, 2017 | 01:18 AM
All Stock Ls2
Ever get your issue resolved?
Old Oct 31, 2017 | 09:09 AM
Paul Theuer
Navigator
I apologize for not replying back. My car is a 2008. No messages about column steering lock. I took it to a shop I trust last Thursday (10-26-17). They did question my radio install but I have not heard anything else since then. I do know they are extremely busy and so am I at this time of year.
Again apologies for not replying back.
Old Oct 31, 2017 | 11:21 AM
jaredtxrx's Avatar
jaredtxrx
U0100 this code more than likely means that whatever code scanner was being used isn't communicated with the ECU correctly.
IIRC GM and Ford have special software that some scanners can't read. You may want to take it to Autozone or a GM dealer to read the code properly.
To No Crank, No Start, 1-Code U0100
