NPP install now throwing MAP Code?!?!
I double checked the lines at the sensor and even added some silicone to the rubber hose that enters the front of the intake but i still have the code.
is there anything else i should try?
If not i am probably going to end up just connecting the lines to the back of the intake at the stock location although ive heard its a pain.
anyone have these issues before?
I forgot to order the tap so I had to use the manifold port , if i had to do it over again , I would remove the manifold before going thru cutting the end of the port open while it is installed on the car
it can be done but be prepared to utter words that you never would have used before in public...
I installed fast 102 manifold and I bet it did not take me 30 minutes start to finish and that included swapping over the injectors . just need an inch pound torque wrench and go easy on those long manifold bolts
Dave
