I assume you have no problem with starting the engine, the other door, or the trunk/hatch and you've tried it both passively (no fob button push) and actively (yes fob button push).
If that's correct, then the problem is the door latch solenoid is not being activated. It could be a wiring problem or the solenoid has failed. Search door latch solenoid for more info and a youtube video for replacement.
thank u , everything else works , only that door not , I will look at the latch solenoid on youtube , once again thanks
