Headers and heat
Old Oct 26, 2017 | 11:22 PM
CMY SIX's Avatar
CMY SIX
Default Headers and heat
What have some of you with headers done to control melted plug wires and starter problems, I've got the woven socks for the plug wires, what has worked well for you. THANK YOU.
Old Oct 27, 2017 | 12:54 AM
Curt D's Avatar
Curt D
Crammed and stalled with 1-3/4 ARH ceramic coated (locally). Running MSD wires w/o any protection. I have DEI reflective tape on the starter.
4000 or so miles without any issues.
Old Oct 27, 2017 | 08:08 AM
double06's Avatar
double06
The LS motor and headers the good thing is they seem to have good distance between the header and plug wire. If you go with a 1.75 inch tube that will help more. The starter that can vary depending on header manufacturer and tube size.
Old Oct 27, 2017 | 09:20 AM
CMY SIX's Avatar
CMY SIX
KOOKS 1 3/4 it's an LS2
Old Oct 27, 2017 | 11:19 AM
89Roadster's Avatar
89Roadster
I use the Accel ceramic wires, they can sit right on the header without burning.
I bought some of the foil tape and covered every wire near the headers and converters.
Old Oct 27, 2017 | 11:44 AM
cstapp99's Avatar
cstapp99
I’m running stock wires with my TSP 1 1 7/8” headers - no clearance issues. No melted wires.
Old Oct 27, 2017 | 12:49 PM
All Stock Ls2's Avatar
All Stock Ls2
1. Ceramicoat 2. Heatwrap 3. Reflective tape or 4. New wires
Old Oct 27, 2017 | 01:13 PM
JDP Tech's Avatar
0JDP Tech
Former Vendor
We've got wires with 135 degree boots and Kevlar heat socks that we use in our packages and they work great with headers. Please feel free to call or email us anytime with questions.
Regards,
Brandon
801-545-4215
Old Oct 27, 2017 | 01:37 PM
hungryhippo's Avatar
hungryhippo
Never had problems with either. Running uncoated kooks headers
Old Oct 27, 2017 | 03:58 PM
redbird555's Avatar
redbird555
Never had an issue even with stock gm wires on my ARH sets even with 2" primaries
Old Oct 27, 2017 | 06:06 PM
BigBlok502's Avatar
BigBlok502
I have the same, Kooks 1 3/4", with stock plug wires w/Hinson socks (they are longer than most socks and go all the way to the coil). Nothing on the starter because I think the OEM Cats got just as hot as the headers, if not more so. I also used insulated wrap on the clutch line on the Drivers side, and on the transmission cooler lines.
The Kooks have been on for over a year now with no heat related issues.
Old Oct 27, 2017 | 06:36 PM
NJ_phil's Avatar
NJ_phil
Kooks 1-7/8 ceramic coated headers, Stock plug wires and these:
https://www.summitracing.com/parts/dei-010542/overview/
Worth the extra $$$ since they can take $1800f
Semper Fi
Old Oct 30, 2017 | 12:41 PM
2L8LUZ's Avatar
2L8LUZ
Just turn the plug wires so they are furthest away from each header pipe...
Simple...no burning..lots of space
Old Oct 31, 2017 | 01:09 AM
All Stock Ls2
Did you ever decide what to do?
Old Oct 31, 2017 | 07:11 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
There is nothing needed. Ran 17/8 uncoated headers with stock wires for a few years and never had an issue.
Old Oct 31, 2017 | 08:04 AM
All Stock Ls2
I simply decided to get msd wires because I wanted to but I didn't have any issues either
Old Oct 31, 2017 | 10:23 AM
CMY SIX's Avatar
CMY SIX
I've already have MSD wires and the "woven" socks for the wires. I'm still debating whether to get or make a heat shield for the starter, I've got one coming for the clutch line but not even sure if it's needed but it can't hurt. once I get the old exhaust out I'll be able to see if there's any potential problems but hearing from all of you tells me there won't be much if any.
To Headers and heat
Old Oct 31, 2017 | 11:41 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Doesn't hurt to wrap the starter for safety. I never had an issue but did it while things were apart.
Doesn't look great but does the job, and nobody sees it. LOL
Old Oct 31, 2017 | 12:59 PM
Seadawg's Avatar
Seadawg
No issues here either - running uncoated LG Super Pros 1 7/8 with high flow cats on an LS3 dry sump. The dry sump lines run between the header tubes too.
Daily driver in hot Florida heat (except for this week)
Old Oct 31, 2017 | 07:28 PM
CMY SIX's Avatar
CMY SIX
I tend to agree with the "it can't hurt" way of thinking
