Can RDCLR effect Bluetooth?
Old Nov 2, 2017 | 11:09 AM
FerrellDBrian's Avatar
FerrellDBrian
6th Gear
Default Can RDCLR effect Bluetooth?
I have a 2005 base. I installed a Pioneer AVH-X490BS head unit. Everything functions flawless except streaming music. It skips randomly much like a scratched CD would. The phone calls even work fine as far as I am aware. I have even swapped head units and the issue is still persistent. I've tried two different phones as well to see if it was a phone software issue. My last guess is it could be the RDCLR unit since it is located above the radio. I know it operates off a 315mhz signal and Bluetooth is a 2.4ghz signal. The vehicle suffers from the common no key fob found error about 50% of the time. So my question is because the RDCLR is searching for the key fob in the vehicle can that affect the Bluetooth signal?
Old Nov 3, 2017 | 03:45 PM
schizcat's Avatar
schizcat
In theory, no, it shouldnt. The newer C6's should have the RDCLR in the same spot and they have bluetooth OEM head units. That being said, I know that phones can interfere with the signal from the RDCLR to the FOB. I think it is the signal more than the bluetooth though.
