Engine bay fuse box/block
Was sitting in car in repair shop and while could not see all, they did take top of fuse box off
everything I have checked points back to the fuse box. when I installed my supercharger I put a jumper wire across where the relay turns the pump on to make sure the BAP was working and I have been having intermitting problems ever since. I think I spread the leads apart to much with the jumper wire.
The GM solution is to solder in a jumper wire below the fuse box at the lower blocks, so they don't have to open or replace the upper fuse block assembly isntead.
Yes on having to straighten/remove the lower flair on the grommets to get the fuse block apart into its three pieces (main block, and top/bottom covers). Once the fuse block is apart, then you can often just clean up and bend the U's back together to solve the bad contact problem. Also, allows you to either replace the wire runs, or at least snap it out if its end clips to tab points that may be needs to be cleaned up instead.
https://www.corvetteforum.com/forums...dlights-5.html
And as pointed out, your really don't need to rebend the bottom flairs back out, since the fuse block bolts will hold it in place. Hence just take a dremil with grinding stone to make short work of removing the grommet bottom faired sections, and when you go to reinstall the fuse box again with only the tops of the grommit'ss flared flat, the fuse box bolt will hold it all together in the car.
If down the road you want to install need grommets, can walk you throw the way I made new ones on the lathe; including a draw through bolt and nut type tool that will first flair the bottoms of the new grommet sleeves once installed in the block, then peen them flat in the end (top flairs are done in the lathe before hand ,hence live end to start the flair, then my centering bearing tool that is just driving into the fared ends to make them flat against the chuck).
Just a trigger for the BAP's own spst relay, correct????
If so, then the fuse box relay should only be seeing about 450ma, and should not be the problem of why the fuse box terminals for the relay are heating up to begin with.
Also, don't use the light gauge fuel pump wires in the fuse box to try to drive current down them from the BAP to the pump. Make sure that you have the fuel pump wired from the BAP thick gauge wires as close as you can to the fuel tank, taking the OEM fuel pump light gauge wires from the fuse box to the fuel tank out of play.
My relay never got "hot". when I say hot I meant car got to temperature. Hot under the hood.
I have my hot wire ran from the alternator to the rear fender well where the BAP is mounted with the 2nd relay. Basically the gray wire stops at the 2nd relay.
Last night I tinned the legs of the relay and its fitting nice and snug so we will see. the reason I think its a bad connection in the fuse box is when it's not getting power I can put a jumper wire in place of the relay and it gets power fine. starts good and everything. Remove the jumper and no power with a relay installed. Swap out several relays and magically just starts working with any relay.
Your problem is not the U part of the clip, but the connection point of the wire runs in the box to the side clip point of the prongs instead.
Forget the circled area, but instead look up right to the U prong and its side wire clip point isntead.
Hence when you tinned the relay and installed it, it forced the side prong over to increase the tension of the lower side wire clip wedge point over enough to semi solve the loose/corrode/burnt wire to lower side clip point; but don't hold your breath for it to last long.
Hence if the wire is not burnt through and need to be replaced itself, then may just have to pull the wire up from the side clip point, clean the side clip point connector point (and maybe the wire point as well were is going to reclip back in), re-install the wire back in the clip, and use a set of needle nose to tighten up the side point clip to wire, as well as any other U prong tabs that may to too far spread apart.
Also, a light coat of dielectric grease does wonders on the not only the wires/prongs/wire clip points after they have been spray cleaned, but future problems too. Not only does is slow down any corrosion of the wires and prongs, but helps to display heat as it trying to build up at the contact points too.
