Top end rod ?
A friend told me he had a ls7 motor with "blown top end rod " ? What does it mean ?
Thanks for help
Hence the ls-7 comes oem with ls7 sodium filled valves that are lighter and helps to transfer heat better than a solid valve. The glitch is that the OEM guides for them in the heads is not the best in the world for a motor that will rev to 7K, so as the valve guides quickly wears, it can cause problem with the valves head snapping off instead. Gm has come out to state that is some motors, the valve guides where not machined correctly (that the motors quickly snap a vavle), while in other cases that GM has not addressed, it just the valve guides worn out to cause the problem in motors with more milage instead.
So with the LS-7 motor since when a valve head does snap off and does major damage, there is a per-empted strike to solve the problem before the motor is blown instead.
Being that the heads are pulled, the Valves are replaced with SS valves, and new valve guide installed/fitted to the new SS valves. Do the new valve guide last longer than the OEM's, not really over all on a motor that is reving to 7K, but when the guides to valve stem fit does become loose again, less likely for the SS valve to snap a head off instead.
To be blunt, the sodum filled valves are light years better for the motor than the SS valves, and any one racing the motor will use the sodium filled valves for this reason. But at the same time, heads are pulled often enough to make make sure that the valve guides channels for the valves are still in spec (fit between the two), and any sign of out of spec tolerances and the guides (and some times the valves as well) are replaced.
So what have we learned, LS-7 is a great motor since it's a 427 in a 383 block, but will not hold up to 100K of mileage if it spends all it time being played rev ranger instead. In the case of stock motors that the guide was not correctly machine and still under warranty, GM has no problems replacing the stock motor. On the other hand, if the motor or tune was mod'ed to pull the motor out of warranty, then your own your own when a valve snaps isntead.
A friend with an ls7 was at a traffic light stop waiting and a valve dropped he just pulled off to the side into a parking lot instead of shutting off the engine immediately as a result the block and one head was destroyed if it happens at wide open throttle catastrophic.
I must admit I never heard the phrase "top end rod" as there really is no rod in the top end so your friend is likely not a wrench doctor you may want to ask him what that means,
I asked him again and he said again : "blown top end rod "
I do not know if it is possible to break the titanium rod in ls7 , not in stock engine.
The rods have a big end and a small end holding the piston with a wrist pin perhaps is what he is referring to as is the top part of the rod take some pics and share your findings with us.
What mods does he have.
The other problem with NOS on a stock motor, you can spin a lower rod bearing just as quick as well.
