Brake pad/rotor sets for 06 Z06
Getting around to changing the brakes for the first time since I bought the car. Rotors are a bit worn too.
Anyone have suggestion for daily driver z06 that sees interstate and traffic?
Also, what is the deal with padlets or one piece? What does the OEM have? I couldnt clearly see what was on the car but looked like one piece.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
OEM pads are three piece padlets. For rotors on the street OEM works fine at around $90 a piece. For replacement pads go with Carbotech 1521 or Powerstop Z26. Both are great low dust pads that work perfectly fine on the street. Go with a full pad
Supporting Vendor
St. Jude Donor '11,'13
If you want a quality aftermarket pad I recommend the Carbotech 1521 pad in the 1 piece design. A low dust pad that is rotor friendly and performs like OEM and last longer. 100% non-corrosive dust will not harm your paint or wheels. This pad also contains NRS technology. Carbotech uses NRS technology on all C4, C5, C6 & C7 front and rear brake pads.
1 piece pad gives you better pedal feel more pad surface and even wear rate.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested I will be happy to help you out or you can order online here http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out for your 5% discount.
ZO6/GS part numbers 1 piece pad.
F: CT1185-S $275.50 with promo code z28.
R: CT1185R-S $233.70 with promo code z28.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
For rotors OE is fine for street use and relatively inexpensive.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
speedz06 (12-10-2017)
