2005 C6 Rear Differential Issue
Old Dec 11, 2017 | 09:42 PM
moiboy22's Avatar
moiboy22
Default 2005 C6 Rear Differential Issue
I am trying to see how bad by rear differential is. The passenger side diff stub has a wobble to it. Any ideas? Below is a picture and Video.
2005; 3.15 Ratio
Video:
Old Dec 12, 2017 | 05:02 AM
User Omega's Avatar
User Omega
It needs to be rebuilt. Call Jeremy Jones at RPM transmissions. He can get you fixed up.
Old Dec 12, 2017 | 05:53 AM
Dano523's Avatar
Dano523
Cooked bearing and/or bearing race, the seal is worn out, and would dare to guess that the clutch pack is toast as well.
As for having the 2005 diff beefed up on the rebuild (stage 2 with Z06 left and right shafts), it only going to help a small amount, since the weak link of the 2005 diff is the case itself.
Old Dec 12, 2017 | 10:26 AM
moiboy22's Avatar
moiboy22
Thank you so much guys for the word. I figured it was shot and am about to get a low mileage used or more likely new one. My transmission started slipping too so I'm in for a holiday punch to the pockets.
Something tells me Santa doesnt deliver 3.73 or 3.42 Differentials under trees.
Old Dec 13, 2017 | 09:11 AM
05 Wreck's Avatar
05 Wreck
Does the DTE 2005 differential brace help with the weak link (differential case) issue?
Old Dec 13, 2017 | 11:22 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Do not use the 2005 (use 2006+) case and do not use DTE (use RPM). The first is stronger and the second is more reliable. I speak from experience.
Old Dec 13, 2017 | 12:03 PM
irok's Avatar
irok
Santa does deliver from RPM but he will want a lot of cookies and milk
Old Dec 13, 2017 | 01:23 PM
timd38's Avatar
timd38
I would buy a 2006 up diff in the used parts section before I would spend money on 2005 diff.
Old Mar 5, 2018 | 04:36 PM
moiboy22's Avatar
moiboy22
Thanks all. Sorry for the late update. I ended up purchasing a used diff to fix this issue.
Old Mar 5, 2018 | 04:46 PM
05 Wreck's Avatar
05 Wreck
What ratio did you end up with?
Old Mar 5, 2018 | 06:23 PM
moiboy22's Avatar
moiboy22
Still with a 3.15. I didnt care to pay for the tune and couldnt find much better without breaking the bank. After getting the new transmission I was done spending money on fixes.
Sucks though because I am still troubleshooting another issue. Link to that thread below.
https://www.corvetteforum.com/forums...hold-idle.html
To 2005 C6 Rear Differential Issue
