Electrical problem
Old Dec 15, 2017 | 08:59 PM
Kiwi53's Avatar
Kiwi53
5th Gear
Default Electrical problem
On my 2005 windows, trans lock out,heater and radio do not work I have check fuses any ideas seems like all the above have something in common
Old Dec 16, 2017 | 11:54 PM
CMY SIX's Avatar
CMY SIX
you have TWO fuse boxes have you checked ALL the fuses and relays?
Old Dec 18, 2017 | 03:50 PM
Dano523's Avatar
Dano523
4 really,
You have the engine fuse box under the hood, then in the passanger foot well, you have the fuses on the BCM, the fuse box under the BCM that has a cover on it, then another one with cover to the right of the BCM.
with the covers removed at least on the fuse box to the right of the BCM; with the fuse box below the BCM cover still on,
Full Monty of the three fuse boxes and what each fuse does in the passenger foot well,
http://www.wiringdiagrams21.com/2009...d-relay-table/
As for if all the fuses and relays are good, would start by diconneting the battery, then pull the red and blue connector from the BCM to clean there pins and sockets, then reinstall the connectors to see that solved the problem. If no, then may be a blow trace or cold solder joint in the BCM that you could correct yourself by pulling the BCM board to trouble shoot it (if you have the talent).
To Electrical problem
