Front Suspension Noise Help
Old Dec 20, 2017 | 11:45 AM
Hellbringer's Avatar
Hellbringer
Default Front Suspension Noise Help
Hello,
I have a pop from my front suspension what to see if anyone else has had this problem and might know what it is.
For the details
- When ever i am turning sharp (into/out of a parking spot) going from left to right it will pop several times
- When ever i am driving and i take a left bend it will pop and then when i go around a right bend it will pop, but if i have 2 left bends in a row, the second bend i dont get a pop (almost like something is sliding)
- bumps is the road do not cause the pop. seems like it is turning
- except, when i am slowing down to come to a stop, just before the car stops i will get a pop.
- Have have had the car on a 2 post and 4 post lift and i dont see anything loose, dont see any witness marks, no play in the wheel bearings, or ball joints, checked the upper shock mount, they seem tight....
- Also, my alignment is spot on and not changing and steering is super tight.
Any suggestions?
Michael
Old Dec 20, 2017 | 08:53 PM
crusher1's Avatar
crusher1
End links are probably the culprit. I had the same issue a few years then replaced front and rear end link. No more noise.
Old Dec 23, 2017 | 07:59 PM
usctroj836's Avatar
usctroj836
Default Front end pop. 2009 Zo6
Originally Posted by Hellbringer
Hello,
For the details
Any suggestions?
Michael
I had the same issue. Then a constant scraping sound. Front bearing went out. Had some kind of bearing kit put it. Apparently more complicated than just a ball bearing. Did not make the car undrivable. Take it to somebody that knows front suspensions. I go to the Chevy dealer. I am on my second extended warranty.
Old Dec 24, 2017 | 12:40 AM
HOXXOH's Avatar
HOXXOH
and that'd be my first guess. The second guess would be dead/dying rubber pads on the leveling bolts.
Easy way to check, would be to remove the front sway bar and drive the car. If the noise is gone, it's end links. Do a visual on the leveling pad thickness, which should be roughly an inch thick.
Old Dec 26, 2017 | 10:49 AM
davidfarmer's Avatar
davidfarmer
The sway bar can also shift to one side, causing to to make contact with lower control arm. You should check the three wheel bearing torx bolts on each side(back side of spindle), the upper and lower ball joint nuts, and the caliper bolts.
Old Sep 21, 2018 | 10:43 AM
Daguilar89's Avatar
Daguilar89
1st Gear
Hello,
For the details
Any suggestions?
Michael
Did you ever figure out the popping sound? I have a ford expedition with the same exact problem. Thanks
Old Sep 21, 2018 | 11:35 AM
Sox-Fan's Avatar
Sox-Fan
Ford expeditions all do that eventually. different issue. try the ford expedition forums.
To Front Suspension Noise Help
