PIP-5037 master cylinder
Old Dec 27, 2017 | 03:29 PM
Jrock817's Avatar
Jrock817
Default PIP-5037 master cylinder
so i lost my clutch after a minor fender bender, and i replaced the fluid, but still no clutch. it has been brought to my attention that there is a TSB for this problem. i call the dealerships close to me, one guy said GM wont pay for it, its a TSB not a recall, and another dealership said that unless the clutch pedal is physically imoveable to the floor, they wont cover it. this leaves me to the choice that i should just get a new master cylinder, and have a mom and pop shop replace it. another thing the guy from place 1 said is that i have a 2013, and it only covered 2008-2012. any suggestions?
Old Dec 27, 2017 | 10:30 PM
Dano523's Avatar
Dano523
Read this link and understand that the end plunger of the master cylinder can fall off on the old design, and what the recall on the master cylinder was all about.
https://www.corvetteforum.com/forums...-pressure.html
Hence the new improved master cylinders end plungers do not pop off isntead.
If this is the problem with the end plunger popped off on the master cylinder, then GM will replace the master cyclinder for free.
If the problem is not the end plunger that has popped off the end of the rod in the master cylinder, then the problem is not the recall problem isntead.
Hence pull the clutch pedal assisted spring and just pump the pedal by hand a few times. If the plunger is still on the rod, you will feel it even if there is air in the lines, while if the plunger has popped off, there will be no resistance as you pump the pedal by hand isntead.
Old Dec 28, 2017 | 07:29 AM
Jrock817's Avatar
Jrock817
so, I remove the spring, and if there is any resistance to the clutch, my plunger should be ok, if it is just all floppy, I can bring it to the dealer and likely have the recall taken care of? thank you for the reply!
To PIP-5037 master cylinder
