Muffler Help--need quieter than Atax
Hi Vetters,
Have a 08 LS3 automatic. Love this car.
Previous owner put on Borla Atax.
The more I drive it, the louder it seems. At 70, I can't hear myself think.
Inventoried the Borla system, have Borla 3" stainless cat back, then 2 1/2" over the axle into those small Atax, about 6" diameter and maybe 12" long.
Have a buddy with stock mufflers with 2 1/2" from the X pipe back. One muffler tech says, "it might work?" He wasn't sure how to go from 3" to 2 1/2...so I drove on ...wrong shop
Will the stock go on? How do to go from 3" to 2 1/2" ???
Is there a "quieter" to fit the Borla over the axle pipe?
All advice on quieter is appreciated.
Thanks Charlie
Thanks Charlie
I really like the Corsa sets I've had in the past. Sport is a little louder than stock and on par with the NPP option on the throttle but no drone. I've had Flowmasters and a couple of the other big name brands and Corsa wins hands down. It's a cleaver design straight through with holes that let the sound wave enter chambers that reflect the waves back canceling the noise.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Maybe give this Corvette Forum vendor a call? They probably know a whole lot more about Corvettes and exhaust.
https://www.vengeanceracing.net/
Thanks Guys, I found a stock set and had them put on at the Buy A Vette service center.
Now it is too quiet. LOL. Maybe next month I will look for some Corsas. Thanks
I like my '08 Base model with the NPP exhaust system. I have the mild-to-wild conversion that works flawlessly, always has. No, it's not loud like the aftermarket systems, but it is loud enough that I can hear the LS-3 and it sounds good with the pop-back when I let off the gas. Drive it in the open mode most of the time unless I want to hear my audio system. If you look around you may be able to find one that has been removed from similar year-model.
Your system already steps from 3" to 2.5" per your description, so I can't see why it wouldn't work...although some photos would help. All it would take is a step down slip fitting at the rear end of your 3" mid-pipe, which would need a 2.5" ID to mate to OE 2.5" OD over the axle pipes.
I have the newer style Borla S Type II and it's a great sound. Quiet until you get on it, then a nice crescendo of sound and a great burble when you let off. If you like Borla that's the one to get.
