Throttle body
Old Dec 28, 2017 | 03:48 PM
vetsvett's Avatar
vetsvett
Default Throttle body
Just a quick question;
If I get my throttle body ported, then the computer will detect more airflow and compensate with more fuel - correct? If so, will that make the 02 sensors (or some other sensor) freak out a little and counter that result?
Its an 05 coupe, non zo6, A4, Halltech CAI, B&B cat back exh.
Thanks in advance
Old Dec 30, 2017 | 09:11 AM
Dcasole's Avatar
Dcasole
No problems at all will be encountered ....the ECM has plenty of room to compensate for a ported throttle body .... but on a stock car you will not see any gain .....put the money towards a intake manifold or headers ....
Dave
Old Dec 30, 2017 | 12:02 PM
Unreal's Avatar
Unreal
Won't see peak power gains, but a ported TB can show gains on throttle response and how the car drives if that is what you are after. If it is just more power, then skip it.
Old Dec 31, 2017 | 03:38 PM
vetsvett's Avatar
vetsvett
Yes, thats all I'm looking for is some throttle response.
Thanks for all the responses.
Old Dec 31, 2017 | 09:05 PM
CMY SIX's Avatar
CMY SIX
you want throttle response get a good tune,
Old Jan 2, 2018 | 08:46 AM
BadAV's Avatar
BadAV
Or a Vitesse throttle controller.
Old Jan 2, 2018 | 06:07 PM
Dano523's Avatar
Dano523
Yep, GM played with the inlet shape of the TB to get a good flow balance around the entire vain movement percentage openings.
With some porting, the flow is not longer even close to linear across the vain's travel positions, making the car much harder to drive in actual street type driving conditions (semi turning the TB into more of an on/off switch instead).
Hence before you go to have a TB ported, have them print out a flow chart of the TB flow volumes through the vain's opening percentages, then another flow chart of throttle percentages after it ported. In oem, the flow is pretty linear with the different TB vain positions, while in the ported TB, no very linear isntead.
Old Jan 2, 2018 | 11:46 PM
Cherokee Nation's Avatar
Cherokee Nation
Get the V-Max throttle body and you will love the throttle response a lot of different then stock....A cheap mod.
Old Jan 3, 2018 | 08:14 PM
Daddy Freeman's Avatar
Daddy Freeman
This guy has some on his home page at the bottom. From what I understand this guy is one the best in the midwest.
http://www.mikenorrismotorsports.com/Home_Page.php
Old Jan 3, 2018 | 10:30 PM
All Stock Ls2's Avatar
All Stock Ls2
You won’t see noteable power gains but the throttle response is very nice!
Old Jan 3, 2018 | 10:47 PM
Cherokee Nation
To Throttle body
