C6 Temp contoller
If you have access to a low-wattage, pencil-style soldering iron and rosin-core solder, take the unit apart and go over the joints that look dullish in color.
Any electronics repair can probably do that as well.
Good Luck
Good Luck
I did the write up on resoldering the C5 HVAC unit.
the C6 unit comes apart in the same way.
I just replaced the bulbs in my C6 HVAC control.
The temp dial pots are dual purpose, being that when you turn it from side to side, it sets the temp, while if you push the button downward, it will turn the system on and off on that side instead.
Note, if the entire controller is tuning off, and not just one side, suspect a cold solder joint on the board.
Now on the pots (potentiometer), they are funky design, since they use a small rubber cup like that on a key board pad as there return springs on the very bottom of the assembly.
like the part top right, but only much smaller instead.
Over time the rubber spring piece will start to fall apart, and this will allow the button to press inwards on it own to kill the system side, and some cases, even allow the dial to slightly turn to change the temp setting under hard acceleration as well.
The pots can be pulled apart to rebuild them (replace the rubber return spring) if you have the talent and extra rubber cups, while if you don't have jeweler type talent to pulls something this small apart, but just soldering skills instead, them the pots can be replaced on the board isntead.
Note, same thing happens on the radios as well, since it uses the same pots as well. Mousers sells replacement pots, and will need to dig up the replacement part number since I have it someone on my laptop file away for safe keeping(the Ac/delco pot is numbered 15452 on it).
And don't feel bad, since I need to pull my controller to check for a cold solder joint on the ambient light voltage circuit, since it's acting up.
Hence HVAC controller unit sends out 5v to the ambient light sensor up on the dash, and depending the voltage coming back from the dash sensor, whats you to turn the the head lights on.
Right now, I getting intermediate problems when I turn the DRLs off, and in less then bright light and colder conditions (the colder the key point here), getting a DYI message to turn the head lights on, meaning that I have a cold solder joint in the system on the board that is causing an intermediate reduced volt in the circuit itself on the board when it colder, and before the inside of the car warms up to warm up the controller (dash sensor if fine).
So with your entire system shutting off and off, bank that that cold solder joints will be easy to spot, once you have the board in hand.
