Ground Location in Passenger Footwell?
I've removed the entire Bose system including the amp in the passenger footwell. My M2W switch ground wire was attached to the amp mounting bolt. I guess the amp case must have been grounded through the wiring harness because that bolt is no longer grounded. Where's another grounding location in the footwell? Maybe I should just tie in to the amp wiring harness. Anyone know what color the ground wire is?
Race Car Tech
Here is a pic.
If you still want to use the amp harness to ground, the wire color is Black/White which goes to G04 underneath the battery tray.
here is the connector end view and pin locator
The following 2 users liked this post by 4SUMERZ:
FLC6GS (10-14-2023),
S.C. vette (01-06-2018)
Race Car Tech
