Anyone experience broken axles with an A6 trans?
Received 2,062 Likes
I'm trying to determine where axles might break on cars with A6 transmissions. If you broke one, was it a stock or aftermarket axle? Did you have a high stall converter? Were you using drag radials? What rwhp or 1/4 mile ET? What rear gear ratio?
Any pics appreciated.
Did you have axle loops? If so, were they mounted inboard or outboard?
Broke a stock axle at the outboard end. Car was on stock converter at the time. Running 10.40s at 135ish. Was on MT 275/45/17s. I have axle loops that I are mounted about the middle of the axle. If one breaks at either end you just don't want it thrashing around taking out any wires, cables, etc in its way.
HOXXOH (01-08-2018)
Supporting Vendor
- Several years prior to the red car being stolen the clamp on the boot of the left one let go and starting throwing grease everywhere so I replaced it with a C5 axle
- After at least 5000 passes and 90K miles, I finally broke the right stock axle while launching the car at Sonoma one morning and it ended up looking pretty much like realcanuck's did.
- At that time the axle was the last remaining original driveline component as literally everything else had been swapped out by then.
- I replaced it with another C5 axle and it surprisingly broke again only a few weeks later.
- I was going to just replace that one with a stock axle again but due to some a**hole trying to get me tossed from the track for not having the proper safety equipment, I ended up being forced to upgrade to aftermarket ones.
- My first choice was a set from The Driveshaft Shop but the wait time was close to 2 months, so I went with a set from GForce since Summit Racing had them in stock.
- After less than 20 passes I noticed the one on the passenger side was starting to come apart so I sent them back to Summit and got a full refund.
- I eventually installed a set of DSS axles and never noticed any issues prior to the car being stolen.
- Around that time (July 2015) I installed a DSS set on the black car and after several hundred passes they still seem to be holding together.
Build details:
- 2007 Corvette, 6L80E with an LS7 and huge cam
- Approximately 600rwhp (based on ET and trap speed since I've never had the car on a dyno)
- 3.42 C6 Z06 stock differential
- Custom transmission brace
- 315/35/17 Hoosier drag radials
- Yank SS4000 converter
- 1800RPM launch
- Mid to high 1.3 60ft times
You probably already know most of these details Tom, but here's my axle history:
Build details:
Build details:
- 1800RPM launch
