Need your help. I own a 2005 c6 z51. The problem I have is out of the blue very random. The car will not start. Nothing when you press the button not even a click. All lights horn alarm work fine. Any suggestions will be greatly appreciated.
thanks
Welcome to the Forum, Al and congratulations on your C6!
You would probably get more input from the C6 General or Tech/Performance section on this. https://www.corvetteforum.com/forums...-2005-2013-14/
Sounds like a problem with the relay or contacts in the starter push button, but I'm sure someone else in the C6 community has better info.
Best wishes resolving this issue.
thanks
I had exact same issue last August.my problem was crank relay wire terminal and connector on starter end of crank wire from fuse box.the female terminal on the end of that after all these years had lost tension and not making proper contact on solenoid.bought and installed new terminal and connector from GM for about $10. no issues with it since.as your car sits now move the connector by hand on the solenoid to see if car will crank.possibly could be your problem
