Bilstein Sports vs Bilstein B8
Old Jan 11, 2018 | 05:15 PM
Mike's LS3's Avatar
Mike's LS3
Default Bilstein Sports vs Bilstein B8
As the title says, what are the differences between Bilstein sports vs Bilstein B8's?
Are the B8's replacing the "Sports"?
Will the B8's have the same ride height as the sports on a Z51 suspension?
Old Jan 11, 2018 | 05:34 PM
MTPZ06's Avatar
MTPZ06
Just from inferring what I've read, it sounds as if the B8's are designed for vehicles with lower than OE ride height.
Old Jan 13, 2018 | 09:53 AM
Purple92's Avatar
Purple92
About a year ago - I was looking for some Bilsteins for a non Corvette application. The B4 is supposedly similar to OEM damping. The B6 & B8 are a bit more aggressive - but hardly "race oriented". Supposedly the B8 is for vehicles that are lowered.
If you want "more aggressive" damping - you might want to give Doug Rippie Motorsport (DRM) a call - they have Bilsteins that are custom valved. I am running a set, and I'll tell you - they are significantly different than the OEM dampers on my GS. Significantly more aggressive valving. Not recommended for you if your idea of taking the Vette out is to drive the wife to the Country Club on a Saturday night, but if you bought the Vette with the handling package because you want the car to handle - they just might be the ticket...
Old Jan 14, 2018 | 04:05 PM
Ragtop 99's Avatar
Ragtop 99
i have the DRM shocks on my z51. Ride height is about same as stock as measured by how often I scrape speedhumps in my neighborhood. They are firmer than than stock Z51 shocks, but the handling and control are much improved, especially on less than ideal pavement.
Old Jan 15, 2018 | 11:03 AM
jaredtxrx's Avatar
jaredtxrx
B6 = Sport
B8 =HD
New vs Old naming
The B8 has a more aggressive dampening profile than the B6. The shocks won't change your ride height and either will work for a OEM or slightly lowered (stock bolts) Corvette just fine.
Old Jan 19, 2018 | 08:14 PM
hubes's Avatar
hubes
Originally Posted by jaredtxrx
B6 = Sport
B8 =HD
New vs Old naming.
I think you got that backwards
Old Feb 8, 2018 | 03:06 AM
Vette_Fan's Avatar
Vette_Fan
Old Sep 8, 2025 | 01:36 PM
stingr69's Avatar
stingr69
Wrong thread
To Bilstein Sports vs Bilstein B8
