Anyone know where I can find instructions on how to wire msd 2 step with a switch and relay?
I want it wired where I would have to hold the clutch down and press the momentary button to enable the 2step. when I let go of the clutch the 2step is disabled. can someone help me with this please?
don't run it on the pedal and just hand held button. you can press it (hold) 2 step box would be active on ground wire, when you let go, box will turn off.
