Malibu
Old Jan 17, 2018 | 03:42 PM
Ape1437's Avatar
Ape1437
1st Gear
Default Malibu
Service traction, reduced power, and service esc lights are on. I was driving down expressway and it slowed right down putting about 30 mph. I drove it to a stop and gave it a minute to reset then started back up. Drove it to get a diagnostics test done and it read Pcm indicated TCs malfunction invalid serial data received. What can I do to avoid costly inspections and repairs on it?
Old Jan 17, 2018 | 06:01 PM
Dano523's Avatar
Dano523
Post the actual code number and it will point you to one of the modules that either has a loose/corroded connector that caused the loss of communication for as second , or the module going out instead.
