can anybody help me with torque specs on a dart ls next block? I used the stock bolts dart supply's with the mains caps. I'm trying to instal my windage Trey and need to remove 6 of them to add special spacers to make it fit. Want to get the motor assembled tomorrow! Thanks guys
Richie333
From Dart website, look under Tech Help, Tech Packets, then pick out your block, all info is there.
Torque Specs - Main Caps
7/16" bolts 65 ft lbs w/ CMD # 3 high pressure lube.
3/8” bolts 40 ft lbs w/ CMD # 3 high pressure lube.
Originally Posted by Red06Vette
Richie333From Dart website, look under Tech Help, Tech Packets, then pick out your block, all info is there.
I didn't know that. Thank you sir!
