Neutral Whirring Noise?
Old Jan 27, 2018 | 12:34 PM
dfalliaux's Avatar
dfalliaux
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
Default Neutral Whirring Noise?
Hola amigos, been some time since I've been on the forum...what have I missed
My 2005 Z51 manual sprung a leak at the radiator, passenger side, on Thanksgiving day. Car has 48k on the clock.
About the time of the leak, while the car is sitting in neutral, I hear a weird whirring noise? I depress the clutch and the whirring noise eventually spins away? Not sure how else to describe this.
Hop on RockAuto and locate the ACdelco rad and lower support (it took a shot apparently and needed replacement) have it all replaced, lines etc, all fluids swapped.
Noise is still prevalent? Any ideas?
Old Jan 27, 2018 | 02:21 PM
dfalliaux's Avatar
dfalliaux
Here's a video I just took
I've been reading forums extensively and from most accounts, this whirring sound is normal?
Whirring sound fading is when the clutch is depressed.
Old Jan 27, 2018 | 04:39 PM
torquetube's Avatar
torquetube
https://youtu.be/KWjMY5Xw914
Definitely not normal. It's something inside the torque tube or the input side of the gearbox, probably a bearing.
Old Jan 27, 2018 | 05:31 PM
dfalliaux's Avatar
dfalliaux
Thanks for the feedback, I'll start troubleshooting there.
To Neutral Whirring Noise?
