Cam Swap
I've seen so many negative comments from several years ago on Corvette Forum about the GM "hot cam" # 88958733 GM promotes that I'm hesitant to go this route. I'm told that my stock valve springs are good for .530 lift and this cam stays within this parameter at .525. GM also says this cam will give me 50 more hp and 50 more ft lb. tq. Retaining the stock valvetrain and exhaust will definitely help me keep the cost down.
I'm not interested in all out hp/tq since driveline dependability is a concern also.
From what I can tell the only thing that needs to be changed is the cam itself. I notice that there is a tool that holds the lifters away from the cam, and a tool that holds the dampener away from the chain, so I don't even need to pull the intake, or even the oil pump. Suggestions?
