name that sound game!
Old Feb 26, 2018 | 06:51 PM
drewz06's Avatar
drewz06
thing knower
Default name that sound game!
anyone ready to play?
2007 c6 z06 manual
sound like it's coming from the firewall...
questions are allowed
thanks!
drew
Old Feb 26, 2018 | 06:56 PM
Lees LS2's Avatar
Lees LS2
https://youtu.be/cbpbYMccdUc
2007 c6 z06 manual
thanks!
drew
wtf!!! lol sounds like a stray cat my wife feeds lol
Old Feb 26, 2018 | 06:59 PM
drewz06's Avatar
drewz06
thing knower
ah so that's where my cat went...
I'm guessing torque tube bearing....
Old Feb 26, 2018 | 07:02 PM
Lees LS2's Avatar
Lees LS2
haha, hope its an easy fix
Old Feb 27, 2018 | 03:08 AM
Dano523's Avatar
Dano523
Would dare to guess that you have a coupler going south in the torque tube.
They are rubber with cords and as they start to go out, the cords will sling off the inside of the torque tube like a violin obw string to make that kind of noise.
part 28 and there is one front and one back on drive line in the torque tube.
As for if the couplers when south like above, replace the bearings at the same time.
If you are really throwing major increased power down the drive line, then instead of the using the OEM couplers, use something like the six shooter couplings instead. They have poly bushings so they still dampen a touch, but billet bodies that are not going to torque come apart like the OEM units instead.
Old Feb 27, 2018 | 03:20 AM
bfit's Avatar
bfit
Mmm wheel bearing
Old Feb 27, 2018 | 07:45 AM
drewz06's Avatar
drewz06
thing knower
good stuff!
stock as far as I know, was a Chevy cpo from the dealer....
I had thought wheel bearing but I can change the pitch of the sound by engaging and releasing the clutch in neutral while moving at 40mph....
also, rolling while in neutral, if I rev the engine, the pitch changes as well, which leads me to believe drive line issue....
I'm going out on a limb, but I'd also assume it may have something to do with my reverse "slamming" into gear....
dealer said they need it to be broken for them to file a warranty claim so I have to drive it some more....
sounds like some sort of strange supercharger.... very loud outside the car.... stops at about.80
thanks for the input! will let you know...
drew
Old Feb 27, 2018 | 04:41 PM
Dano523's Avatar
Dano523
good stuff!
If the car is rolling, with the drive line's speed at a constant, and revving up the motor changes the pitch, then may not be a coulper, but a problem with either the slave's TB, the clutch, or the pivot bearing/flywheel/starter instead.
Bottom line, the drive line will need to be dropped, so the drive line and the clutch (its parts) and be check to get to the root of the problem.
With the car still under warranty, take it into the shop now to be corrected, instead of waiting and something to really go south later; with such maybe causing you to wreck the car instead.
Old Mar 2, 2018 | 06:47 AM
drewz06's Avatar
drewz06
thing knower
yeah I figured this qualified as broken and had made an appointment, taking it in this morning...
so, if I'm moving at speed with the noise, and depress the clutch, I still hear the noise.
if I rev the engine with the clutch in..... the sound remains constant, does not increase with engine speed.
when rolling at speed and shift to neutral, let out clutch, still the same sound.
no sound at a stop in neutral... I can't really hear it when I try to increase engine speed in neutral, thanks exhaust....
but the noise is significantly louder under load as opposed to coasting in neutral
anyway, will let you know what the techs say
update, tech will look at it, taking it back Tuesday....
​​​​​​also, yeah it definitely has a violin like sound now that I listen to it....
Old Mar 2, 2018 | 08:59 PM
Dano523's Avatar
Dano523
Going back to coupler's, and not had to tear them up when someone is abusing the drive line with a torque of the LS7, via violent launches,burn outs, shift changes.
Hence as the motor loads up the torque tube, the couplers flex to end up with the loose cords slinging against the inside of the torque tube more.
Old Mar 14, 2018 | 08:32 AM
drewz06's Avatar
drewz06
thing knower
so, the transmission "is shot".
looks like some bearings in the case were going bad and there were metal fragments.
tech submitted a claim for an entire new transmission....
aftermarket warranty hooray! 😃
getting them to swap in a new clutch and slave cylinder while it's out... I got two years on the warranty and the clutch isn't covered....
I'll update once I get it back and get the paperwork / talk to the tech.... hopefully it's a 6060 and not a 56
To name that sound game!
