Finally an smart accessory drive that makes pulling and replacing the driver side head easy and the front of the engine simple and accessible for service.
Looks great for a passenger side low mount turbo to me.
Only thing I see is all holding the entire accessory system (correct me if I'm wrong) is the 6 8mm water pump bolts but at list I get something to work with adding two head mount bolts may do.
That’s a pretty damn neat setup for sure. The pricing isn’t bad for all the stuff that comes with it either. From looking at the instructions, it looks like it has the truck pulley offset though, so I seriously doubt it could fit behind the steering rack in the C6.
Their claim is they haven't found a car it wont fit in I must admit I assumed they tried it on the C6 but will be prudent to ask.
It's on the "mid" belt line which is the F body belt line. The Corvette drive is on the "short" belt line. The truck drive is on the "long" belt line.
Thanks that's good info I like to make the car easy to work on and that kit looks like if you remove the water pump the whole deal comes out just lay the ac compressor on the side and have at it.
