GS Brake Pad Replacement
Old Mar 11, 2018 | 07:05 PM
SSWEET's Avatar
SSWEET
Default GS Brake Pad Replacement
Going to go from padlets to single pads. Have read several threads, still not sure if you use the padlet clips if going to single pads. Some threads said their single pads came with out any clips others say used the padlet clips from the oems padlets, others say you don't need clips with single pads.
Any help from some one who made the switch on the GS brake pads would be appreciated.
Old Mar 11, 2018 | 08:28 PM
a_k_00's Avatar
a_k_00
I just put single piece, StopTech pads into the Z06 calipers on my car and you do NOT need the clips. The Caliper Pins keep the single pads aligned.
Old Mar 11, 2018 | 10:08 PM
gsflyer2011's Avatar
gsflyer2011
I kept and used the oem clips when i switched to Carbotech 1521 monoblocks. (Single one piece pads)
Old Mar 11, 2018 | 11:42 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
If going to Carbotech 1 piece pads the factory clips work and I suggest using them.
The Carbotech 1 piece pad will drop right into the caliper and you don't have to take out the caliper pins or spring clips. The spring clips are critical in keeping the brake pad square to the rotor surface and ensuring that the pads slide smoothly along the pins. The spring clips also assist in reducing the noise inside the caliper.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Mar 12, 2018 | 12:51 PM
R_W's Avatar
R_W
I went Carbotech 1-piece and reused the metal clips. Padlets are a stupid design, IMO.
C6 GS
To GS Brake Pad Replacement
