Oil leak at high RPM?
Well, I took a wrong turn last week and somehow ended up in Mexico with a new Mustang revving at me. I took the bait and easily put him in my rear view mirror, but now have a concern.
When I ran him my car smoked pretty badly from the engine bay area. I don't believe I over-revved and everything sounds fine. I pulled over to check it out and see that quite a bit of oil had sprayed on the exhaust, causing the smoke.
Since then I've had a light leak when driving normally. I've tested going into high RPM several times since then and sometimes it leaks considerably and sometimes it doesn't.
There's enough oil everywhere that I can't trace it. Does anyone have a starting point?
Check the oil pan. You’ll need to get it up on a lift and see where it’s coming from, but an oil pan leak will leak onto your exhaust and cause smoke to come out from under the car, especially at higher RPMs..
Honestly I thought the high RPM trigger would rule out the oil pan.
Is your valve covers remove the driver side cover and you'll see why is going on the exhaust, connect your driver side valve cover rear plugged breather to the air inlet like the right side do not T the two sides.
oil filter leaky? I wonder if you have a double-gasketed filter? Also possible your oil cooler lines are leaky if you are so equipped.
Thanks for all the suggestions everyone!
I had the same experience when I stupidly installed my front crank/harmonic balancer seal backwards, which caused the lip of the seal to get torn. It didn’t leak at idle or parked, but when I blasted it to WOT, the crankcase pressure would push the oil out and it sprayed everywhere under the car. I only realized it was leaking when noticed the blue smoke in the rear view mirror coming out the back during a run. The whole underside of the car was coated with a oil film. I would check behind the balancer to see if it’s wet with oil. If so, most likely the seal is bad or has worked loose somehow.
When I had my cam installed a few thousand miles ago they replaced the balancer. Now I'm curious if he put the crank seal on backwards.
How did you figure that out? I'm a little uncomfortable putting the car on my lift then having someone floor it while I'm under there to see where it's shooting from.
Good thought. When I was under there last night I noted there is oil midway up the engine, so I think that probably rules out the oil pan as a major leak.
EDIT: Please note that even if the seal isn't torn, but installed the wrong way around, it will probably allow oil to escape once you build crankcase pressure at high RPMs, because the seal is designed with a lip that uses pressure to press that lip inwards to enhance the seal around the balancer hub. So, if its installed backwards, it will instead allow the lip to blow away from the hub, thereby allowing oil to bypass the seal. Unfortunately, there's only one fix for that, and it involves tearing down the whole front of your engine again, and removing that damn steering rack. I managed to figure out an "easy" way to completely remove the rack though, so if you figure out its the seal that's leaking and need to pull it down, let me know.
Check and double check the valve cover gaskets and the bolts that secure it down. Mine are currently leaking at a small enough rate that I'll get to it when I get to it but it drips on to my passenger side header.
I appreciate the replies. They're all helpful whether or not they fix my leak. Now I know areas to keep an eye on.
I'm tired of being under the car for now so I'm going to give it a few days and look again.
Before you go under the car take a paper towel and swipe it across under the valve cover above the header flange see if it comes out wet.
I have considered dyeing the oil, but there's so much down there I wasn't sure how well that would work. But there's really no reason not to try after I clean it up as much as possible.
I finally have a chance to get it to a local shop. When speaking with the owner he mentioned that I should order a Catch Can for him to install and that it will probably fix the oil leak issue.
I'm concerned by this because I have not made any changes to the car that would have increased crank case pressure. It just started leaking like this after heavy driving. So this seems like a band-aid instead of addressing the issue.
I can throw a catch can on there myself, but I'm still concerned that there is an underlying issue that needs to be addressed.
What are your thoughts on this?
