Oil temp
Old Mar 24, 2018 | 10:32 AM
Frisbee's Avatar
Frisbee
5th Gear
Default Oil temp
What is normal operating temp range for oil?
My LS3 runs abt 230-240 at 70mph cruz with outside temps are 70 degrees.
Old Mar 24, 2018 | 10:45 AM
EVRose's Avatar
EVRose
That's normal.
Old Mar 24, 2018 | 06:23 PM
Boomer111's Avatar
Boomer111
My LS3 runs a tad cooler oil cruising at 70 mph 225*+ a bit. This is with 4:10 differential too.
I have seen 235* when in 100+* weather and driving 100 miles per hour for extended time.
It take me at least 30 minutes driving at highway speeds to get oil temp to stabilize. This is just normal driving no heavy footing.
Old Mar 25, 2018 | 02:03 PM
RobJoy's Avatar
RobJoy
Once mine is warmed up the oil temp always runs higher than the coolant, and I have the Z-51 package which includes an external oil cooler. Don't know how much help the oil cooler is but as I recall it runs about 215 degrees. I guess this is why GM recommends the Mobil 1 synthetic.
Old Mar 25, 2018 | 04:12 PM
Jim2003's Avatar
Jim2003
My 2013 runs about 219 degrees at 75 to 80 on the highway in 6th gear. Now on the track I have seen it in the low 240's.
Old Mar 25, 2018 | 05:15 PM
Curt D's Avatar
Curt D
Seems a tad high. 08 base A6, Z51 opt (no oil cooler), cam and I run 220ish at a cruise on 75-80 deg days. Highest I have seen is 234 after a few pulls.
What’s your coolant temps?
To Oil temp
