Alternator not getting power
Positive lead on the meter on the terminal under the back rubber boot on the black of the alternator, and negitive lead on the body of the alternator. Output should be 14.7 volts.
If you don't have voltage, then you need to check the engine fuse box for one of two blows fuses.
As for in line fuse, it's right before the starter connector from the cable that comes off the alternator. Hence it under the long rubber shelding of the end connector.
Hence the bottom most cable, under the rubber on the cable off the connector. As for what the fuse is, it just smaller gauge short piece of wire, with a fire retardant around it and a first rubber layer (so it does cause a fire when it melts through), then is in between the connector and the larger cable wiring with second layer of rubber (again all under the rubber coating just off the connector).
so the link is like this below, but a 1" long piece of wire cabling about 3/4 the gauge of the main wiring on the cable, weld in between the end of cable and end connector above.
If you have Zero volts at the actual alternator while idling, then you have a blown fuse in the fuse box or bad connector on the alternator itself.
Hence the alternator uses the Horn fuse as a voltage sensing circuit, as well as the ECM controlling the output of the alternator as well.
So if you can honk the horn, the alternator bench checks fine on a test machine, then you have a problem with either the top connector on the alternator with cracked wires at the connector, or it's a back up line wire/connector problem, and could be all the way back at the ECM being bad isntead.
Bottom of diagram above is the alternator (generator),
B far left is the positive output terminal on the back of the alternator under the rubber boot (body of the alternator is ground). D-C-B are the on the snap in connector on the top of alternator. D goes back to the horn fuse, while C and B wires from that same connector goes back to the ECM.
