Swaybar bolt tap size?
Old Apr 8, 2018 | 12:35 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default Swaybar bolt tap size?
Cross threaded the bolt that holds swaybar bushing in place.....what size tap is needed to chase those threads?
Old Apr 8, 2018 | 09:43 AM
rkj427's Avatar
rkj427
Pro Mechanic
sizes below.......... different front and rear...........
also depending upon how damaged the threads are, you may also want to consider a heli-coil insert to repair..................
FRONT sway bar attaching bolts: M10 x 1.5
REAR sway bar attaching bolts: M12 x 1.75
Old Apr 8, 2018 | 09:45 AM
timd38's Avatar
timd38
I stripped one and put in a Heli Coil, no problems for 8 years.
Old Apr 8, 2018 | 10:37 AM
C U IN REARVEIW
It is barely cross threaded....but didn't want to drive it up in there and take the chance of making it worse. Will try and just clean out threads and see what happens...thank you guys!
Old Apr 20, 2018 | 03:35 PM
Bludevlsi's Avatar
Bludevlsi
Anyone know where I can get new bolts for the sway bar bracket. Lost one on my c6 rear drivers side.
To Swaybar bolt tap size?
