Occasional Active Handling message
Recently I've experienced the Active Handling kicking in when making left turns with the wheel turned at 30+ degrees usually at speeds over 35 mph.
Had a friend with a Tech II come over to help me diagnose the issue. Both the yaw sensor and the steering position sensor showed no faults but there was a correlation error between the 2 sensors.
Assuming it was the steering position sensor I started to gain acces to the lower end of the column and heres what I found.
There is no way that the bearing can just pop out of the retainer. It was NEVER installed correctly from the factory
As for once you get into the steering column part, should be easy to figure out what part gave up the ghost and needs to be replaced.
https://www.wholesalegmpartsonline.c...ering%20column
Also, before you reconnect the column to the steering rack, make sure that the steering wheel position sensor is reading O with the wheel/tires straight. Hence you can clock the steering position sensor a full rotation out when you connect the column back up to the steering rank, and will cause problems. If the voltage is reading +, then the column shaft is turned one rotation to the right clockwise, while if it reading on the -, then the shaft is spin one rotation left/counter clockwise isntead.
The sensor retainer you are moving around with your fingers just need to be snapped into it's retaining position and the occasional Active Handling notice will go away for good and the bearing will stay in the bracket cup.
(No thing is broken at the present time)
The only thing needed is with the steering in straight up position to align the sensor retainer to is correct position bearing in place, apply some silicon spray to both parts to aid in getting it to snap in to place.
Let us know how this worked for you good luck, David.
XBoost The lower bearing was never snapped into its retainer there is no way to dislodge the bearing with the column assembled. The column has to be removed from the car to install that bearing as there is no way to apply enough force to the bearing to get it to snap into its retainer.
Car is all back together and exhibits no problems now.
Pics are of lower bearing and how it is held in place along with steering position sensor
Order of pics is kind of jumbled
Column as removed from car you can see where the bearing is supposed to snap into
Steering position sensor retainer
Steering position sensor inplace
Steering shaft bushing and snap ring in place
Lower column bearing snapped into bearing retainer
