Inside air temperature sensor
Old Apr 30, 2018 | 04:03 PM
grady's Avatar
grady
Default Inside air temperature sensor
I have the gauge bezel removed from the car but how does this part detach from the bezel?
Old Apr 30, 2018 | 04:56 PM
EVRose's Avatar
EVRose
It just snaps on. You may have to twist it, I can't remember.
Old May 1, 2018 | 02:49 AM
Dano523's Avatar
Dano523
It just push snaps in, but has a tab on the left hand side, so make sure that the tip of the blue piece is pointing upwards as you are push snapping it back in place.
Also, once you snap the bezel back in, look through the slots to make sure that you can see the blue piece through the slots.
If loves to pop back out as you put snapping the bezel bottom back in last, and will cause nothing but problems with the A/C controller not seeing the real temp in the cabin when it laying in the bowels of the dash isntead (will think that you are going through menopause with the cabin temp too hot, or too cold instead) .
Look close and you can see the blue part of the sensor to know that it did not pop out as you re-installed the bezel.
Note, the starter button can be tricky as well. So it it does not want to snap in correctly, start one side first, then snap in the other side. On mime, I have to snap the steering wheel side tab last, for the button to stay snapped in seated correctly.
To Inside air temperature sensor
