Brake flush
Old May 1, 2018 | 06:06 PM
DEFC6N1's Avatar
DEFC6N1
Default Brake flush
Hi All, I plan to flush my brake system and wondering what fluid I should replace with. I plan to track my car occasionally so please keep this in mind with any recommendations.
Old May 1, 2018 | 08:39 PM
Mordeth's Avatar
Mordeth
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Motul 600
Old May 1, 2018 | 09:21 PM
96GS#007's Avatar
96GS#007
Motul 600 or Ate Type 200
Keep in mind that if you plan to track the car, you need to bleed more frequently. I recommend every 90 days or before each event, whichever is longer.
Cheaping out and having the brake pedal go to the floor after a 100+ mph straight is a poor time to discover that saving $30 was a bad choice.
Old May 1, 2018 | 11:10 PM
tw78911sc's Avatar
tw78911sc
Also, even after your bleed the entire system, take the car out and go hard on the ABS, the ABS unit has a reasonable amount of fluid that doesn't bleed out, forcing the ABS will cycle out the bad/old fluid in it.
Old May 2, 2018 | 02:45 AM
Dano523's Avatar
Dano523
The C6 ABS unit has a pump that really needs to be cycled to drive the old fluid out of it, then the rest of the system be power flushed next.
So that way I do a power flush since I do have a Tech II,
Start with removing the fluid from the reserve tank, cleaning the tank, then filling it with fresh fluid.
Now using the power flusher on the tank, will power bleed the passenger rear caliper until it flows clean with the fresh fluid to begin with. At this point since I have fresh fluid all the way down to the ABS unit, will use the tech II to do a basic brake bleed, which will cycle the ABS valves and ABS pump to push the old fluid out of them, draw in new fluid.
Once that is completed, then will go back to a normal power bleed again, being passanger rear first until if flow clear again, then driver rear until if flows clear, passansger front, and then final drivers front: all the while making sure that at no time has the brake resivor become half full or less of fluid instead.
______________________________________
As for brake fluid, Motul 600 a the high boiling point for a Dot 4 fluid (594), but can be spendy and over kill if not needed instead.
https://www.lelandwest.com/brake-flu...ison-chart.cfm
Hence if your going to street drive the car mostly, and then after each HPDE event if you are running street tires/not getting the brakes that hot to begin with, do a quick power bleed again after each HPDE event, may be better off with prestone dot 4, which is a hell of lot cheaper instead.
Note, will take about a quart of fluid to do a power flush correctly, so about $20 of fluid with prestone dot 4 each time, verses about $60 using Motul 600 instead.
And no, do not have anything against Motul 600 since it very good fluid with a high boiling point, but it's more than most novice drivers need, and by having a less expensive fluid that they can use to do the power flushes after each HPDE event, more likely to do the needed power bleeds after each event, so the fluid is always dry, and not dealing with water contaminated older fluids that may have a lower boiling point instead.
Hence Prestone 4 has a dry boiling point of 510, while Motul 600 that has adsorb moisture out of the air from not being change enough, may have boiling point of 401(wet) instead.
Also, don't use dot 5 or 5.1 in the vet!!!!!!
Use dot 3 or dot 4 only.
Old May 2, 2018 | 08:26 PM
davidfarmer's Avatar
davidfarmer
https://www.walmart.com/ip/Prestone-...fl-oz/20746453
Prestone Dot 4 is great, it's cheap, and it's available locally usually. My O'Reilly has the larger bottles generally in stock.
Old May 2, 2018 | 11:08 PM
Vette_Fan's Avatar
Vette_Fan
Originally Posted by davidfarmer
https://www.walmart.com/ip/Prestone-...fl-oz/20746453 Prestone Dot 4 is great, it's cheap, and it's available locally usually. My O'Reilly has the larger bottles generally in stock.
I've been using Prestone products for a long time. How's the Valvoline Synthetic Dot 4 compared, any differences?
That's great info . Questions, since I am considering getting it done at a regular repair shop (for lack of tools/skills), they do power flush brake fluid, how to you recommend I ensure they follow the right process to replace the fluid from ABS also?
Old May 3, 2018 | 11:01 AM
Dano523's Avatar
Dano523
Again, the break down boiling points on brake fluids.
As for Valvoline Synthetic Dot 4, its a Dot 3/4 high breed, and has a boiling point of 480.
So the Prestone Dot 4 is about the same price and has higher boiling point of 510 instead.
Old May 3, 2018 | 12:49 PM
dmk0210's Avatar
dmk0210
I always ignore the dry boil point and look at the wet boil point. The Prestone and Valvoline don't look as great with those numbers (311).
I usually use ATE typ 200 or Motul 600. Those are both rated about 400 deg.
Old May 3, 2018 | 05:14 PM
dr_gallup's Avatar
dr_gallup
Nice link but it seems like quite a few brands just list the DOT specification minimums for their boiling points, particularly wet. Maybe that's really their true performance but since there are quite a few I suspect their legal department made them do that.
Edit:
Just noticed that the Red Line wet & dry numbers seem to be reversed. Not sure I believe the Carbone Lorraine wet number either, expect that's dry.
To Brake flush
