What kind of 60' times can you squeeze out of an R888R tire?
Like the title says... I'm curious to see what folks have been able to get. I know it's not a drag tire, I know they are built for cornering. That's why I want to get a set. I have 0 interest in running a drag tire on my car. Just curious what I may be able to get out of these vs something like the MSPSS
The don't have the heat problems as the Cup2's shedding thread ,but with the deep scalping, it does sound like you are over driving the car on the track every corner instead.
Worst yet, the scalping if very, very deep on the R888's, so once you do get down to the bottom of the scalping, the tire is cooked. With the Cup 2's, you have plenty of tread left after you have worn down past the grooves isntead. As for the MPSS tires, disconnected tire, and it's the MPS2's the replacement tire for it instead.
As for 60's times, all depends of the how well the track is prep's, the car, and the driver behind the wheel (to get the car out off the hole to begin with). Hence Cup 2 will have more grip than a R888R, and R888R will have more grip than a MPS2 instead. Where the MPS2 shines over the other two tires, is when you have to drive the car and the road is wet isntead.
R888r tire is mixed blessings.
There is a lot of variables in an equation like this. For instance what size rear tires do you even have?
But I can tell you that I've had Michelin pilot super sports and I now have R888r's and they're not even on the same planet as far as traction goes.
I currently have a road racing alignment but was considering taking my car to the quartermile track just for fun. I'm curious how much of a difference I would get with a proper Drag Racing alignment?
Yep, for road course use, it all about the stiffness of the side wall so you don't get side wall roll on cornering, and then the gooeyness of the rubber.
Very bad side wall roll,
On strip tires, it still about the gooeyness of the rubber, but more so about the side wall being soft/plyable, so it can slightly wrinkle on launch to hold it grip to the ground on launch instead.
So on the R888r, your not going to get side wall wrinkling since the side wall is designed for just the oppiste, which means slightly slower out of the hole, then it's a matter of how well it going to hold once your out of the hole and in the groove as the tire starts to balloon up instead.
Received 2,061 Likes
Use specific tires for the task. Anything less is a compromise with poorer performance.
right right. I am in the same boat as the fella that posted a few back. I am a back road/road course guy, but I'd love to take it to the strip one weekend and see what I could run, without having to drop a grand on a drag pack just for one time at the strip. I don't necessarily want or need to launch hard either, as I'm not trying to tear up an axle. I want a decent launch, with maybe a 1.6-1.7 60' and then I'm more interested in seeing what my trap speed might be than anything else. My hope is 10.9 at 130 mph, although I may well fall short of this since I'm not willing to go bigger on the cam, or put drag tires on the car.
If you find someone to do a loan, try to use your road course tires for a couple passes and then swap to the DR's. The difference is something you can advise others on what to expect from tire types.
I don't know your location (no profile), but around here, racers will loan someone DR's to do one time tests and even go to the track to help them make the best launches. You might try that. It never hurts to at least ask.
anyone else run these at the strip? Again, not looking to set records, just trying to get an objective idea of added straight line traction going from an MPSS to something like these.
Don't let these guys scare you off. Just to see how fast you trap the R888's will be perfect.
R888's have been incredibly popular for fast street cars on the street. I had great luck with them in my swapped rx7, 2800 pounds 475whp 4.10 gears and a T56.
I cut a 1.8 sixty and ran 11.40@130 mph in 100% street trim.
I also managed to cut a 1.76 with RE71r's, but they required a lot of clutch slip and were on a razor edge of spinning. I don't like the RE71r's as much as the R comp for my car. I'm either going to a Maxxis, R888R or NT01 next time around.
I definitely could have gone faster with the R888's if I slipped the clutch more and launched at a higher rpm. I just drove off the line at 2000 rpm and they held 1st gear with no spin.
The second video here is with the RE71r's. My run before this was 11.18 with a 1.76 sixty. This one I got too greedy and the tire couldn't hold.
Bigwebb (05-22-2018)
https://www.youtube.com/watch?v=PvUPkt25IEg
https://www.youtube.com/watch?v=r2k8Yq2NO4k
we're on the same page. Thanks so much for your input.
Daniel
As a comparison, my 3200#, 394whp, LS3, A6, 2.56 gear, Vette ran a 1.74 60' and 11.44 @ 124 with just Nitto Invos on a so-so prepped track right off the street, while vacationing in FL.
A R888R really isn't made for drag racing performance. Like others have mentioned there is much better options out there.
Some people consider the R888 series to be a drag radial but it really is not. Something like a NT05R or NT55R is designed as a drag radial, but still has good street characteristics.
Most of these high performance tires will outperform a traditional street tire either way.
Again, not really looking to launch the car hard at a drag strip on a regular basis. More just trying to get a feel for the straight line traction improvement over street tires. My thought is, if they will cut a significantly better 60' at the track, they should help me better hold the power on the street.
