Stainless Works Headers and X pipe questions
I picked up a set of stainless works headers and catted x for my 08 c6 recently off of a forum member. He pulled them from an LS2 C6. He wasn't sure what the size was but he thought they were 1 7/8, so I pulled the trigger. When they came in, and I measured them, they appear to be 1 3/4, although it's hard to tell the difference, as it's only an 1/8 of an inch. Doing a little digging on the internet, it is hard to decipher what stainless works was making those years. Some vendors have them in stock and say they only came in 1 3/4 and 2" sizes for those years, while other vendors say that they have 1 7/8 available for the 05-08 model years.
So I have two questions.... First, are they likely 1 3/4 or 1 7/8? What does the vendor actually offer? Second, what other brands of headers would fit with the stainless works catted x pipe, should I decide to go ahead and buy a set of 1 7/8" headers? The reason I am considering replacing them, is that I am going full head (TFS 255) and cam with lowered compression, and I don't want to have a part on the car that's going to hold me back, after I've spent that much money.
Thanks in advance for any wisdom..
Daniel
Daniel
simplest method: get a flexible but not stretchy cable, wrap it around the primary, and measure it. Divide measurement by pi = your diameter.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Not trying to be a dork, but have you tried calling them? Are there any numbers on it?
I'd think the company can tell you where to look if there are any. Here's their website. http://stainlessworks.net/ Really, before I asked most vendors, I'd ask the company that makes them.
I would worry about the size of the headers unless your an max effort build. You are gaining a little bit of torque with the 1 3/4 headers verse the 1 7/8.
The difference between 1-3/4 and 1-7/8 is about 0.4" so as long as whatever you measured with isnt super stretchy, you should be good.
yes, its outside dia but with 16/18 gauge it doesnt really matter if youre measuring the inside or the outside if we're moving in 1/8" increments. I believe most exhaust PIPEs are measured via outside diameter anyway.
you're saying the difference is close to half an inch. Are you referring to outer circumference?
daniel
when deciding, be honest where you need torque. Don't dragrace? Probably don't need 1 7/8. Roll in, you may be making even less power till revs build.
um.. 3/4 Is 6/8 so it is 6/8 vs 7/8 or 1/8 inch which is 0.125 inches, right? Just measured mine with calipers, 1.746 outer (1 3/4), 1.62 inside.
circumference changes by 3.14x the diameter (cuz of pi) so a 0.125 dia change will be a 0.39" circumference difference.
