Performance exhaust always on!
Old Jun 12, 2018 | 11:32 PM
MsEllie's Avatar
MsEllie
Default Performance exhaust always on!
Well, I guess my atomic orange roadster, Ms. Ellie, likes to hear herself. I have two fobs to turn it quiet, but no cigar! Any suggestions?
Old Jun 13, 2018 | 11:28 AM
RicK T's Avatar
RicK T
Well, is the car new to you? FOB batteries good? Do the FOB buttons light up when pushed? Did you check the fuse panel under the passenger floor panel to see if the controller is there and hooked up properly?
Could be a bad controller, they do go bad occasionally. Or a wiring / ground attachment problem, pretty common. Maybe post a couple pics of what you have, FOBs and controller installed.
Old Jun 13, 2018 | 03:37 PM
2008 Corvette's Avatar
2008 Corvette
2020 C6 of the Year Finalist - Modified
Default Npp
FYI. Fob battery Duracell 27.
Old Jun 13, 2018 | 04:30 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
What system is it ?
Old Jun 13, 2018 | 06:40 PM
twinarrow99's Avatar
twinarrow99
agree with comments above. check your fuse panel behind passenger footwell. IF you have mild to wild, you should see a blade plugged into where the exhaust fuse normally lives - and extends to a small module with ground wire and short antenna. This of course, if you have the factory NPP dual mode exhaust. simple thing to do if this is the case is to replace the mild to wild blade plugged into the fuse block with a 10a fuse. if dual mode is STILL all open, you likely have a bad solenoid - located behind the RR taillight. somewhat a bear to get to, but simple to replace. otherwise you might have NPP vacuum line issues... happened to me a few years back, the solenoid was visibly cooked. I recall Dano saying the NPP was designed bass ackwards - the solenoid is engaged and overworked excessively.
Old Jun 14, 2018 | 01:09 AM
MsEllie's Avatar
MsEllie
Fob light lights up on both fobs. It worked last fall when I put it to bed. This is the factory dual mode exhaust.
MsEllie's Avatar
MsEllie
Originally Posted by realcanuk
What system is it ?
Good old GM.
Old Jun 14, 2018 | 01:12 AM
MsEllie's Avatar
MsEllie
Good post. Lots of stuff to work with now. Just what I wanted and needed. Thank you.
Old Jun 14, 2018 | 10:28 AM
jrose7004's Avatar
jrose7004
I just leave mine open all the time by choice.
Old Jun 15, 2018 | 12:28 AM
MsEllie's Avatar
MsEllie
It drones like a b#tch when the top is up, but when down, I don't mind that sweet sound at all. So, ya, I hear you on that one.
Old Jun 16, 2018 | 01:03 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
exhaust fuse ok?
Old Jun 19, 2018 | 04:57 PM
dr_gallup's Avatar
dr_gallup
It's vacuum operated so the vacuum line can be bad too.
To Performance exhaust always on!
